07-20-2010 11:13 AM
Here is one involving X-Controls.
Xcontrols are a bit complicated to configure, so it might not be clear what it means if the "data changed?" boolean in the action cluster is set to true.
For example, there is an event case name "Data Change", and the programmer might think that "data changed?" needs to be set to TRUE in that event case. (After all, if you write to a terminal, the data changes in some way, right?
...wrong!
Bad idea, but you might never notice a problem until you do some profiling:
If "data changed?" is set to TRUE in the "Data Change" event of an xcontrol, writing to a plain local variable of the xcontrol in the main program actually fires any "value changed" event associated with the xcontrol, same as if you would write to a value(sgnl) property. This can lead to unexpected behavior. ![]()
07-26-2010 08:29 PM
Wow! I just learned one that threw me for a loop! I rarely use the Expression Node, so when I tried to generate a simple parabola out of instinct I tried "x^2 + 2*x". You can imagine I was shocked to see the following drunken graph:
Apparently, the '^' operator is the XOR operator, not "to the power of" like I expected. This was clearly evident for such a simple formula, but could be much more insidious in a complex formula.
See here for the original thread where I ended up using "x*x + 2*x" as the example.
07-27-2010 09:21 AM
Not sure if you discovered it in your research, but ** is "to the power of". i.e. "x**2 + 2*x"
07-27-2010 11:14 AM
The few syntax differences (formula node vs. parser) are a bit of a weak point and can be confusing.
Here is a list of some differences.
excerpt from the help:
The parser in the Mathematics VIs supports all elements that Formula Nodes support with the following exceptions:
, &&, !=, ==, <, >, <=, and >= are not valid....
The following table lists cases where Formula Nodes and the parser in the Mathematics VIs use different syntax.
| Element | Formula Node | Parser VI Routine |
pi | pi(1) = , pi(2) = 2 , 2pi or 2(pi) return an error |
| Exponentiation | ** | ^ |
The precedence of operators is the same for the Mathematics VIs as in Formula Nodes. Refer to Formula Parsing VIs for more information about specific Formula Parsing VIs.
The parser in the Mathematics VIs uses the following syntax:
function (argument)
08-11-2010 10:59 PM
Have you ever heard of "Coerce to Type"? You may not realize you need this function to squash bugs waiting to happen in data type conversions and typecasts.
04-11-2011 02:05 AM - edited 04-11-2011 02:08 AM
I try to configure a case structure in a way that one case matches all the input strings started with "CurrentMeasurement" (and others.)
This results TRUE, if the input = "CurrentMt" and also TRUE if input = "Currenteasurement". But FALSE for "CurrentMeasuremen"
So what is the rule? In the help I find only hints for string ranges, for example stringe begin with a and b should be "a..c"
Mitulatbati
04-11-2011 02:38 AM
This looks like a normal question looking for help, so please post it as a new thread in the LabVIEW forum.
04-14-2011 04:02 PM
You just gave me an idea for the idea exchange. What if the string could be a regular expression?
04-14-2011 04:46 PM
If an event structure is registered for an event but does not have a case for that event then firing that event will still reset the timeout timer for the structure.
Some people consider it a bug and others consider it to be expected behavior.
There is an interesting debate on Lava about this.
Anyone know why creating a snippet converts a control reference into a control?
04-15-2011 03:22 AM
Because NI wants to encourage people to use the Code Capture Tool which doesn't have this issue and can back-save your snippet as well?
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
