BreakPoint
Interesting Stuff
Greetings from Germany
Henrik
LV since v3.1
Message 61 of 128
(17,118 Views)
In this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=190426&a#M190426
the Graph Master (aka CC) teaches how to easily convert mouse coordinates to XY position on the graph.
Very cool trick!
Ben
Message 62 of 128
(17,023 Views)
Queued State Machines
Message Edited by JoeLabView on 06-22-2006 09:43 AM
Message 63 of 128
(16,990 Views)
In this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=191868&jump=true
We discuss differences in performance of sub-VI's based on where the terminals are located on the diagram of a sub-VI, conditional reads etc.
To help clear up our questions Greg McKaskle "lifted the hood" and let us know how we can help LV re-use the buffers of the caller when data is passed to a sub-VI.
Ben
Message 65 of 128
(16,930 Views)
This thread has a white paper talking about some of the thoughts that went in the current manifestation of OO in LabVIEW.
http://forums.ni.com/ni/board/message?board.id=170&message.id=199651&jump=true
Ben
Message 66 of 128
(16,750 Views)
Here's one I found (again) recently which I haven't seen anywhere else:
http://forums.ni.com/ni/board/message?board.id=170&message.id=152190
Dynamik explains how to use the control editor to edit the cosmetics of one instance of a non-strict type def, without editing the type def file itself.
Jaegen
Message 67 of 128
(16,530 Views)
In this thread
Jeff Peters of R&D explains all of the elements of the boolean's color properties and confirms once and fora all, that there really is a reason to have so many colors.
Ben
Message 68 of 128
(16,201 Views)
DAQmx base will not always assign the same device ID's. See update in this thread.
http://forums.ni.com/ni/board/message?board.id=170&message.id=216339&jump=true
This is NOT a bug but is the nature of the beast.
Ben
Message 69 of 128
(16,163 Views)
Since these two threads will drop of the list in short order, I'm posting links to these threads so we can find them when we need them.
Slow UI events
LV start-up slows down over time
Ben
Message 70 of 128
(16,022 Views)
