BreakPoint
Find a beeline in a log log scale :)
Has been done before, but I just picked some values from the Kudo leaderlist, and found again the beeline in a log-log scale.
However is shows statistically, that altenbach and Ben deserve about double the kudos than they have 😄
Greetings from Germany
Henrik
LV since v3.1
Message 1 of 26
(7,002 Views)
Hmmm...
Maybe I should add a line to my signature asking for Kudoes and/or stop posting and wait for the Kudos before I move on. (Smiley-wink)
Ben
Edit:
I am guessing you are uisng the bulk numbers that lump together Kudos for answers and Kudos for suggestions.  That is like mixing apples and oranges so one should expect fruity results.
Message 2 of 26
(6,954 Views)
I think the problem is that altenbach and Ben give a disproportionately higher number of kudos, resulting in artificial inflation of the lower ranks 🙂
Message 3 of 26
(6,946 Views)
Now you are just asking for kudos, right? 😄
Message 4 of 26
(6,903 Views)
There probably needs to be a correction factor for longtime users, because the chance of kudos/post was much smaller in the early days. (Smaller audience, pre-lithium format, etc.).
I think a second order polynomial would work quite well for the log-log plot. 😄
Message 5 of 26
(6,901 Views)
I remember in the beginning of Kudos, where the first Kudos was an indicator for 'Read by Ben' 😄 😄
And who wanted a early one star rating??
Altenbach: I think a beeline is still valid. The first and last decade (no fractional ranks and Kudos here) shouldn't be weigthed that much. In my Q&D lookup only one sample is repesenting >99,5% of the users. Add the 'last' 3 ,2,1 Kudos user and the line maybe seems to need a 3. order log-log fit ? 😛
Spoiler
Did I just say to not put too much weigth on altenbach and Ben, didn't I ?  😉 😄 😛
Henrik
LV since v3.1
Message 6 of 26
(6,873 Views)
There also is some noise, so I wonder if there are any other outliers that are not shown. For example you only show about 7 dots of the top 10, while it would be easy to show all in that interval.
And yes, the early heavy posters have a biased low kudos count. The prime example is Dennis, who has significantly more posts than me, but fewer Kudos.
Message 7 of 26
(6,865 Views)
I hand copied some values from the list,  I leave it to some html (de)scripters or the ones with the real database access 🙂
Henrik
LV since v3.1
Message 8 of 26
(6,857 Views)
When selling cookies door to door for cub scouts I learned that I was doing good if I sold 1 for every 7 doors I knocked on. I have tried to maintain the quality of my posts to maintain 1 kudo for every other post I make and I am thankful that so many have helped me maintain that level.
And yes, I do give out a lot of kudos! I just say "thank you" more often than most. Trust me it does not hurt one bit to give out too many kudos.
Chilly Charly and I had developed some code to scrape the NI web-site and compile statistics about post counts and kudo counts. That code has been long depreciated with the changes to the forums. If you do take on such a task be aware of two issues.
1) It is only a matter of time untl the site changes and the code will have to be modified.
2) Throttle you scraping to avoid "denial of service" from the site (like I discovered).
But while we are on the topic of Kudos and counts...
Christain is just 4 kudos short of 10K kudos on the LabVIEW forum. A "Knight of Kudoes" is coming soon!
See here!
Ben
Message 9 of 26
(6,781 Views)
Dennis also didn't get any kudos from the idea exchange which would be another reason for the lower kudo count.
Message 10 of 26
(6,775 Views)
