06-04-2007 12:50 AM
06-04-2007 05:06 AM
I doubt people will have any objection and I think it's a great idea. While the tool was originally posted to the Starware thread, the point is not to have it only in places where the writers can get stars, but to get as many people to use it as possible. I would also suggest alternative means of distribution like the LAVAcr and OpenG itself (with the BSD license?).
As for technical issues, the current version is 7.0. I think it should stay that way, if only because it's the version I use . I can help with compiling that. All the 8.x stuff is called dynamically and so adding the code to handle panes (as well as the library names) should be done dynamically as well. We should have a tree VIs which will hold all the dynamically called VIs so that it can be compiled easily on newer versions.
Also, I think that it should have some changes made to it.
Personally, I think some of the additions are not needed and just complicate the program (like using the number buttons to cycle the lists or having the timeout) and unless anyone has objections I suggest that we remove them.
Also, the code which does the actual cropping was never cleaned up and this could be a good chance to do that.
One important addition is the ability to select the position of the FP and BD relative to each other. Maybe from a picture ring?
BTW, what is your suggestion for working with panes?
Can you select objects across multiple panes?
06-04-2007 06:06 AM
I like that, since we have control over the documentation!
Sounds good!
I think you can select, the problem is that currently you get an error if you want to use the whole panel (mult. panes)BTW, what is your suggestion for working with panes?
One addition I want is the 'escape' key, that is quite intuitive to cancel a dialog
06-04-2007 07:33 AM
Well, it's important to know whether you can select across multiple panes or not, because that would significantly affect the behavior of the tool.
In any case, I don't use 8, but I would expect that this should be a fairly simple fix and that if there is no selection the tool should capture the visible part of each pane and combine them into a single image.
06-04-2007 09:33 AM
I would suggest posting the utility to the NI Community website.
-D
06-04-2007 03:47 PM
What actually is the problem with panes?
I ran the FP.Get Image Scaled method and it returns an image of all the panes.
If the problem is that you don't see parts of the pane which are not currently visible, I'm not sure what can be done about that. There doesn't seem to be an exposed way of getting the full image of a pane and I don't know how to play with scripting in 8.x.
06-05-2007 01:50 AM
06-05-2007 10:16 AM
@TonP wrote:
how much control do we have on the NI site?
To my knowledge, you can freely edit anything you post to the NI Community site. I think that's the whole point of it, to encourage code sharing. You can check out the History Probes utility I posted to see an example of what (I hope) a typical post on there would look like.
-D
06-21-2007 09:54 AM
06-21-2007 12:32 PM
