BreakPoint
Can someone help me with this VI?
I pick noise on all channels...
LabVIEW, C'est LabVIEW
Message 1 of 23
(9,030 Views)
I think you forgot to connect the ANTENNA.
It works fine once you do that.
In the future you should post these questions to the machine vision board. It should get you a faster answer for questions regarding how to look at machines.
___________________
Try to take over the world!
Message 2 of 23
(9,018 Views)
I agree with tst that it is probably an antenna problem.
Here in Venice, channel 5,7 and 11 seem to be strong enough to marginally work even without the antenna, see for yourself! 🙂
Another annoying thing: The power button still does not work so I always have to pull the plug to turn it off.
Message Edited by altenbach on 06-04-2005 01:46 PM
Message 3 of 23
(9,022 Views)
I found the problem with the power switch. It was a mechanical problem loose contact.
BTW: Channel 5000 has a clear signal here south of Stuttgart. But we need some work on the sound.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 4 of 23
(9,013 Views)
Waldemar, I fixed the sound on channel 5000. I expected to catch LabVIEW Channel... 😞
tst you are out of your mind, with LabVIEW I'd need CABLE not ANTENNA! Can you imagine a wireless LabVIEW diagram!
Now lets start the game "Enhance this VI" by adding more and more useless or clever features. This is fun!
Message 5 of 23
(9,009 Views)
I don't know you guys, but there is something on channel 13 that is freaking me out...
www.vartortech.com
Message 6 of 23
(8,909 Views)
Yeah! That channel 13 just freaks me out !!! 😄
Message 7 of 23
(8,906 Views)
Actually, this is pretty much what will be on analog broadcast TV in the US after the move to digital TV is implemented (forced) in '09
PM
Message Edited by LV_Pro on 06-06-2005 08:16 AM
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 8 of 23
(8,869 Views)
JP!!
There ARE wireless vi elements... Think about it..
(do U need a hint?)
5-stars to the 1st one who gets the answer!!
Message 9 of 23
(8,937 Views)
To run this on a Mac, change the Sound Format input of the Snd Write Waveform.vi to Stereo, 44100, 16 bit.
Lynn
Message 10 of 23
(8,809 Views)
