Biomedical User Group Discussions
Closed-loop system using signal generator
I am using a USB DAQ 6009 to simulate a ECG signal. I wanted to know if it would be possible to create a closed-loop system in which the signal is generated from the biomedical workbench and then passed into Labview on one of the Analog inputs. I tried creating this. I thought that I should have been able to see the ECG signal in the Data graph in LabVIEW. Am I wrong? Attached are pictures of the current setup I have.
(3,341 Views)
Are you getting an error?
(2,567 Views)
