You should have a look at the Independant Components (IC) by youself or by some criteria, then remove those ICs to reconstruct the signal. In your code, ICs to remove (index) is a input you need to specifiy. For example, if you find an IC with index 5 is the noise signal (like DC drifting) you want to remove, you need add 5 in this input array.
