Reply
EEG biofeedback
EEG biofeedback
hi,
   i am working on a project based on biofeedback where we are analysing EEG signals and giving a feedback to the brain through flickering of lights to reduce stress. i have samples of EEG waveforms of few people. now i have to develop this system in labview. i have to amplify these EEG signals and then i am filtering the alpha frequency range. after filteringi have to follow the algorithm given below:
i)            A .25 second interval of data is analyzed
(ii)         Maximum and Minimum values are determined
(iii)    .7(Max-Min) + Min is determined and set as a threshold value
(iv)    The signal data is then compared to this value
(v)      If the data is > than the threshold the y-value = 1.
(vi)    If the data is < than the threshold the y-value = 0.
(vii)     This outputs a square wave of which the frequency can easily be determined.
i dont know how to go about with this. pls if any one can give me advice or guide me on the right track
Message 1 of 5 (7,881 Views)
Reply
Re: EEG biofeedback
Please find the code for your query attached below. I suppose with a square wave of varying frequency you mean to refer to the duty cycle of the pulse. I also suggest that you go through some LabVIEW fundamentals or take up a LabVIEW basics course. That will enable you to build these codes on oyur own.
Best Regards,
Shivam Awasthi
Message 2 of 5 (7,873 Views)
Reply
Highlighted
Re: EEG biofeedback
To Mr.Shivam
thank you so much sir for helping me.:smileyhappy: i'll surely follow your advice and do a basic course in LABVIEW.
thank you.
Message 3 of 5 (7,865 Views)
Reply
Re: EEG biofeedback
Please also see our on-line NI Biomedical User Group here:  www.ni.com/biomedusers
Visit the NI Biomedical User Group at:
Message 4 of 5 (7,835 Views)
Reply
Re: EEG biofeedback
hello sir,
 i tried your given code with the EEG waveforms i had. it works fine but the square wave generated at the output has frequency of about .6hz whereas i want the frequency to be between 9hz to 12hz. how do i go about with it. what changes should i make and also am attaching my code. please guide me.
Message 5 of 5 (7,811 Views)
Reply
