Reply
ECG Simulation
ECG Simulation
hai i bro i want to know how i can make the ecg simulator with sine signal?
if you know ti please share it with me...
tanx before
(8,704 Views)
Re: ECG Simulation
You could use the Biomedical Startup Kit for what you are doing: http://zone.ni.com/devzone/cda/tut/p/id/6626. If not, you could simulate any sine signal as long as you have the amplitude, phase and frequency information by using the 'Sine Waveform' VI (Functions >> Programming >> Waveform >> Analog Waveform >> Generation >> Sine Waveform).
I hope this helps.
Vivek Nath
Applications Engineer
Machine Vision
(8,691 Views)
Re: ECG Simulation
any project for this ? tanx
(8,683 Views)
Re: ECG Simulation
I am not sure I understood what you meant by a 'project'. If you download the Biomedical Startup Kit, you will be able to see all the functions that should help you get started on the ECG Simulation. I hope this helps.
Vivek Nath
Machine Vision
(8,674 Views)
Re: ECG Simulation
how i can build ecg simulation with sine waveform?
(8,670 Views)
Highlighted
Re: ECG Simulation
I am not sure how exactly you want to perform the simulation, but you can modify the amplitude, phase and frequency of the sine signal to simulate your waveform.
Vivek Nath
Machine Vision
(8,657 Views)
Re: ECG Simulation
Is i want to perform the ecg simulation without toolkit, but i can modify the amplitude, phase and frequency of the signal of simulation.does anyones have the labview of this?
(8,628 Views)
