NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
lumlumer
CANNOT convert MIT format file to TDMS/LVM file
I am pretty new to labview.
I tried to use the file format converter to convert MITformat files into .tdms/.lvm, but having troubles doing so.
When I tried to pick the correct data file of MIT format, it only looks for  the header and annotation files, but not recognizing the signal file (in .DAT format). But the .dat file is the only file that I want to convert to .tdms/.lvm file(or other labview readable formats)....
What am i missing here?!
Thanks for helping!
Christy
Member
ZJ.Gu
回复: CANNOT convert MIT format file to TDMS/LVM file
For a standard MIT database file, it consists of at least two files - filename.hea and filename.dat. The .hea defines the sampling rate, bit format, channel info... Without hea, the file format converter could not know the detailed structure of the dat file.  I think if you download the dat somewhere, there should be a hea file. Try to place the two files in one folder and load in file format converter again.
You could post your question in biomedical user group - http://decibel.ni.com/content/groups/biomedical-user-group. This may be the best place.
Zhijun Gu
Member
lumlumer
Re: 回复: CANNOT convert MIT format file to TDMS/LVM file
Hi-
I did have the header file and the .dat at the same directory. :smileysad: so that didn't work for me.
Member
esmaham
Re: CANNOT convert MIT format file to TDMS/LVM file
Hi Christy,
A quick search returned the following Page . I will keep searching this issue , I'll post more information as soon as I get it.
Thanks and have a great day.
Esmail Hamdan | Applications Engineering | National Instruments
Member
lumlumer
I think i know where my problem lies.
The header file I am working with does not contain all the information like the sample header files have....
Member
lumlumer
Anyone familiar with the .hea format?
I could not fgure out how to make the output signal with a baseline at 0 (seems like that's something i can specify in the header to have the converter work properly?)
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
