03-09-2006 01:26 AM
03-09-2006 10:20 AM
Hi Ashwini,
Perhaps you can explain a little more in detail what are you doing with ncgetnotification. Which parameter you are waiting for and are you doing this for the Network Interface or for an Object? Did you run the NI Spy ? A Spy Log would be helpful too.
DirkW
03-10-2006 02:56 AM
03-10-2006 10:05 AM
Hi Ashwini,
Yes it seems we did some changes to the notification error handling with 2.2, which is also included with 2.3 and makes sense by the way.
In your 2.1.2 spy log file you can see the invoke callback is reporting the error flag. (h11) This means an error occured (hex10 and a frame received (h1)
Invoking NI-CAN user callback (30875856, 17, 11, 0, 1)
Process ID: 0x00000CBC Thread ID: 0x00000FA8
Start Time: 13:59:02.113 Call Duration: 00:00:00.000
Status: 0 (VI_SUCCESS)
03-23-2006 02:42 AM
Thanks a lot for your help.IMy problem is solved.
regards,
Ashwini.
