Automotive and Embedded Networks
Reply
how can i sniff the cancasexl traffic on labview?
Hi, For my last year project i need to observe the data traffic passing through the cancasexl, someone can help me or give me an idea? thank you.
Message 1 of 9 (4,706 Views)
Reply
Re: how can i sniff the cancasexl traffic on labview?
Youssef89,
I did a bit of digging here, and it sounds like VECTOR makes a CANcaseXL labview driver, but unfortunately it is not free. It also seems like They also have a free .NET library, which you could call into in LabVIEW, but it sounds like its a bit tedious, based on a few other threads such as this. That said, most of those forums were pretty old, so I would suggest contacting VECTOR to see what their options look like now.
Kyle M.
Applications Engineering
Message 2 of 9 (4,696 Views)
Reply
Are you trying to monitor the CAN traffic, CAN messages on the bus? Do you have the VECTOR CANoe app also?
You could call CANoe from Labview...
What more exactly are you trying to achieve?
Vincent
Message 3 of 9 (4,670 Views)
Reply
In fact there is another application running on parallel with labview to send the testing frames to the dashboard of a car.
I would like to get the passed frames using labview, than compare the frames to the data base to identify what kind of tests was done on the dashboard.
Message 4 of 9 (4,666 Views)
Reply
[ Edited ]
Youssef89,
If you are trying to interface with a CAN bus to read an OBDII port, you should be able to do everything you need in LabVIEW with a simple CAN device (either NI-XNET or NI-CAN)  and a CAN-OBD-II connector. we then offer full APIs for talking to the bus. You can send and receive any frames or signals you could need from there through LabVIEW. The simplest setup would probably be a USB 8473 with a CAN-OBD-II connector cable. Would that be a viable option? It would circumnavigate needing to used the Vector CAN libraries altogether.
Kyle M.
Message 5 of 9 (4,642 Views)
Reply
Highlighted
Message 6 of 9 (4,604 Views)
Reply
I realise this thread is quite old now but anyone searching may be interested...
There is now a reasonably complete wrapper library for the vxlapi.dll uploaded to the NI Developer Community.
You may wish to have a look at it if you're developing for the Vector XL hardware.
https://decibel.ni.com/content/docs/DOC-30180
Troy - CLD
Each snowflake in an avalanche pleads not guilty. - Stanislaw J. Lec // I haven't failed, I've found 10,000 ways that don't work - Thomas Edison
The greatest of faults is to be conscious of none. - Thomas Carlyle // Beware of the man who won't be bothered with details. - William Feather
Message 7 of 9 (4,045 Views)
Reply
Receive LIN frame with CANcaseXL vxlapi.dll
The tutorial to receive LIN frame works well for my application. I can "listen" communication between the master and the slave with my CANcaseXL.
But now I want to create a "master mode" in which I can send frame to my slave and read the answer.
Does anyone have an example to work in "master mode" with the CANcaseXL?
Renaud
Message 8 of 9 (4,006 Views)
Reply
Re: Receive LIN frame with CANcaseXL vxlapi.dll
The zip file in the NI Communities document mentioned above now contains an example VI that simulates a LIN Network with a master node and a configurable number of responding slave nodes.
I wrote it a long time ago to simulate heavy LIN traffic.
It is not as simple as the other included examples but it does show how to simulate a LIN Master node using the the vxlapi.
Troy - CLD
Message 9 of 9 (3,959 Views)
Reply
