Automotive and Embedded Networks
Using ncWriteMult
I seem to misunderstand how to use the ncWriteMult function.
I think the problem is in parameter 2 of the function, concerning data size. I have tried several combinations but the result is not what I expect.
I don't manage to write the expected number of frames on the CAN bus.
Here is my code.
(3,544 Views)
Hi JCX,
Yes you are right, it seems there is a bug in the CVI function panel code. I passed this to our developers to fix the problem.
I let you know, when the fix is available.
DirkW
(3,518 Views)
Hi JCX,
Here is the Fix for your problem. Copy the LIb FIle to the bin folder within your CVI directory. (C:\Program Files\National Instruments\CVI80\bin)
Recompile your application and try to run it again. Should work now.
DirkW
Message Edited by DirkW on 03-13-2006 10:47 PM
(3,517 Views)
Thank you DirkW, everything is working fine now.
(3,509 Views)
