I know that there is no flush API function in NI-CAN, and that one should use ncAction with op-code reset instead.
However, the manual states that this can only be done for a network object, and that a ncAction/NC_OP_RESET performed on a network object propagates up to all open associated CAN objects, which may not be what one wants to do.
According to the manual, it shall not be possible to perform ncAction/NC_OP_RESET directly on a CAN object (using a CAN object handle). But what if this is exactly what I would like to do?
I want to clear the Tx and Rx queues for a specific CAN object, leaving the other objects unaffected.
Is there a way for me to do this? Can I perform a ncReset/NC_OP_RESET on a
single CAN object?
Thank you in advance for your answer.
