Automotive and Embedded Networks
USB-CAN gateway with one EPOS2 P master controller and two EPOS2 slave controllers
I am using a USB- CAN hardware configuration wherein one master controller (EPOS2 P) is connected to the PC via USB and 2 slave controllers(EPOS2) are connected to the master via CAN cable. it is working in EPOS studio properly but in labVIEW an error saying 'bad interface name' is popping up for the EPOS2s(slave controllers). I have checked the protocol stack name, the interface name and the port name for all the connections in epos studio and then gave them in the labview code accordingly. I am attaching the screen shot for the Labview code and the errors obtained.
If you have any solution, please suggest.
Thanx
vi for USB-CAN gateway
error for EPOS2
Message 1 of 1
(3,842 Views)
