05-04-2015 02:22 PM
Has anyone used the J1939 Transport protocol with NI-XNET in LabWindows? Is there anything built in to XNET or do you just have to handle timing, acks, and message sequencing manually with the Raw Frame format?
Anyone know of any LabWindows examples out there? The only examples I see are in LabVIEW. LabWindows support seems to pale in comparison...which is fun.
05-05-2015 09:22 AM - edited 05-05-2015 09:22 AM
Hi BLowery
I looked through our internal servers and was not able to find any examples for J1939 for LabWindows CVI. As you mention, you can still use the XNET functions to build up your code from there. If you have the chance to open the VIs see the code in the J1939 Transport Protocol Reference Example, this could be a good start point for building up your code on CVI.
Hopefully, if someone has worked in this before, the might be able to provide suggestions or share their resources with you in this forum.
WenR
