06-10-2014 07:48 AM
Hi i'm a student of Università Politecnica delle Marche and we'll partecipate at the next race on Varano for the Fomula SAE (Society of Automotive Engineers) championship. We are using a NI sbRIO 9636 for the telemetry system and i want to receive CAN data from the ECU. The ECU hardware is a MoTec M800.
Have you ever had this kind of problem?
Have you some notions and case for this hardware type?
Thank you so much
06-11-2014 02:33 AM - last edited on 06-19-2014 03:18 PM by Hassan_Atassi
first of all thank you for your posting. About the configuration of sbRIO 9636 and you ECU i think one of most important thing is understand what is CAN protocol and how programm the API to inteface board to your hardware.
Here some links about NI-CAN:
http://www.ni.com/white-paper/2862/en/
Than something about ECU test with NI Products:
http://www.ni.com/white-paper/3312/en/
http://www.ni.com/white-paper/2732/en/
I really hope that this information help you for the championship.
Have a nice day
06-11-2014 09:29 AM
One quick clarification. sbRIO does not use the standard NI-CAN or NI-XNET driver that the majority of other National Instruments CAN devices use. sbRIO uses the NI Embedded CAN for sbRIO driver instead.
06-11-2014 09:40 AM
exactly!!...i have install the driver for NI Embedded CAN to sbRIO and i try to adjust the example in labview for my case. Now i read some information but the number in the stamp is only a series of zero. I'm using the input stream.vi because is the easiest example for start with a CAN comunication (only read in my case).
I'm doing something wrong?
Thank for every answer
