01-13-2009 02:51 AM
01-14-2009 04:13 AM
Have you tried to access the channels from Data Neighborhood --> CAN Channels in MAX?
The reason why you are seeing this error is because you are trying to use the channel API with the USB CAN module (which is not supported).
One thing you can try is converting the channel API to frame API. Here is a KB that explains how this is done:
http://digital.ni.com/public.nsf/websearch/7A7875C000F205DD862572640073B8CF?OpenDocument
Pease let me know how it goes.
Thanks!
01-14-2009 04:51 AM
Hi Morini,
thank you for the reply.
Not being able to use channel API with a USB device explains alot about my error message.
Yes i have tried to access the CAN Chennels in MAX from Data Neighborhood.
As it is now i don't need to use channel API and i can use the frame API (so far i know).
All i was trying with MAX was to get started reading/writing to the CAN. The goal of this is to read/write messages from VB.net to the CAN.
09-24-2015 10:13 PM
May I make friends with you! I have some problems about USB-8473s to consult you! Can you give your QQ to me. Thank you,dear friends!
09-25-2015 07:11 AM - edited 09-25-2015 07:12 AM
The purpose of this entire forum, is to help people who have problems. If you have a problem, post your question with detailed information about what you have, what you want, and what isn't working. While you're at it read the forum guidelines. Posting to a 6 year old thread that you have a question isn't going to get you anywhere.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
