NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Surya_lol
PCAN USB for simulating CAN environment
I would like to Simulate a CAN environment without actual CAN node.
I would like to connect a PCAN USB which is connected to PC to other PCAN USB which is connected to Other PC i.e. I would like to establish a communication between two PCs using two PCAN Usb connecting each other.
Is it possible to connect two PCAN USB interface and simulate a CAN system?
I request to help regarding this.
Member
Marcus Flohr
Re: PCAN USB for simulating CAN environment
Hey,
i guess it is possible. But i think it is kind of complicated.. why not just using Ethernet ?
However, if you wanna do this i think you have to implement the drivers of the PCAN USB device.
Member
Surya_lol
Hi Markus,
Thanks for the replay.
I connected the PCAN USB interfaces and simulated a CAN environment.
I used PCAN USB because this is device we use to monitor CAN node in real set up.
Now simulated environment is working fine in which PC is acting like a real CAN node.
Regards
Suresh
Member
Marcus Flohr
Ah..Great. So your isse is kind of fixed.. ?
Member TCL
Member
TCL
hi surya is it possible to check the device in NI measurement & explorer
Member
Surya_lol
Hi ,
NI measurement & explorer supports only NI CAN devices.
PCAN is not supported by NI.
Hence it is not possible to check this device through NI measurement and explorer.
Regards
Suresh
Member TCL
Member
TCL
can you share some VI regarding initialising PCAN in labview & reading CAN messages
i wll be very thankful to u
Member
Surya_lol
HI,
PCAN is not an NI supported Hardware.So i think its is not possible to configure it through Labview.
I didnt used Labview for my set up.I used PCAN view.This application software is supplied by PCAN user interface vendor(Peak systems).Through this you can configure the PCAN hardware,send and receive messages.
Member TCL
Member
TCL
i had built the VI & its working  thks for reply
Member
Surya_lol
oh...thats great!!
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
