Dirk's answer is right on. I would be curious as to what port you are using, and whether you expect this to be a high speed or a low speed CAN network. Let us know and we can help you out. Was this card working before, or is it a new card? If the port you are using is bus powered and you do not have power on the bus, the transceivers will not transmit anything and you will see the behavior that you are seeing with MAX.
Hope this helps.
Scott B.
Applications Engineering
