02-06-2016 01:09 AM
Dear Sir,
I try to program XNET (CAN & LIN) with C#.
I found the example for the ANSI-C.
I try to conver this example to C#, but it's very difficult to me.
Some body already have .Net Wrapper for XNET API? and can share ?
Hiawath
02-11-2016 03:35 AM
Hi Hiawath,
There's currently no support for our customers willing to use XNET with a .NET programming language. As per the example in C and the use of P/Invoke, you can create a C# wrapper for your needs, yet we cannot really assist you in doing this.
A useful document to get started:
- http://www.codeproject.com/Articles/403285/P-Invoke-Tutorial-Basics-Part
You can also share you experience with your local sales representative in case he can figure out a better way out for you.
--Eric
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
03-06-2016 03:13 AM
Dear Sir,
I try to wrapper for the "nixnet.dll" and worked very well for the "nxCreateSession" and "nxWriteSignalSinglePoint".
But I can't get the data from " nxReadSignalSinglePoint" , even though compile OK,
Can you see "nxReadSignalSinglePoint" and advice ?
Andrew.
using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading.Tasks; using System.Runtime.InteropServices; using System.Threading; namespace ConsoleApplication2 { class Program { public const string DLL_NAME = "nixnet.dll"; static IntPtr g_SessionRef; static IntPtr g_SessionRef2; [DllImport(DLL_NAME, EntryPoint = "nxCreateSession", CallingConvention = CallingConvention.Cdecl)] public static extern Int32 CreateSession(string DatabaseName, string ClusterName, string List, string Interface, UInt32 Mode, out IntPtr SessionRef); //nxStatus_t _NXFUNC nxCreateSession( // const char* DatabaseName, // const char* ClusterName, // const char* List, // const char* Interface, // u32 Mode, // nxSessionRef_t* SessionRef); [DllImport(DLL_NAME, EntryPoint = "nxReadSignalSinglePoint", CallingConvention = CallingConvention.Cdecl)] public static extern Int32 ReadSignalSinglePoint(IntPtr SessionRef, out IntPtr ReadValueBuffer, UInt32 SizeOfValueBuffer, out IntPtr TimestampBuffer, UInt32 SizeOfTimestampBuffer); //nxStatus_t _NXFUNC nxReadSignalSinglePoint ( // nxSessionRef_t SessionRef, // f64* ValueBuffer, // u32 SizeOfValueBuffer, // nxTimestamp_t* TimestampBuffer, // u32 SizeOfTimestampBuffer); [DllImport(DLL_NAME, EntryPoint = "nxWriteSignalSinglePoint", CallingConvention = CallingConvention.Cdecl)] public static extern Int32 WriteSignalSinglePoint(IntPtr SessionRef, double[] ValueBuffer, UInt32 SizeOfValueBuffer); //nxStatus_t _NXFUNC nxWriteSignalSinglePoint( // nxSessionRef_t SessionRef, // f64* ValueBuffer, // u32 SizeOfValueBuffer); static void Main(string[] args) { string l_pSelectedInterface = "LIN2"; string l_pSignalArray = ""; string l_pSignalArray2 = ""; string l_pSelectedDatabase = "IG"; string l_pSelectedCluster = "Cluster"; string l_pSelectedSignal1 = "LH_HeaterSWLEDHigh"; string l_pSelectedSignal2 = "LH_HeaterSWLEDMid"; string l_pSelectedSignal5 = "LH_HeaterSWLEDLow"; string l_pSelectedSignal3 = "LH_HeaterSW"; int g_Status = 0; double[] ValueBuffer = new double[2]; IntPtr ReadValueBuffer = IntPtr.Zero; IntPtr TimestampBuffer = IntPtr.Zero; /// for read from LIN l_pSignalArray = l_pSelectedSignal1; l_pSignalArray += ","; l_pSignalArray += l_pSelectedSignal2; l_pSignalArray += ","; l_pSignalArray += l_pSelectedSignal5; // for writing to LIN l_pSignalArray2 = l_pSelectedSignal3; l_pSignalArray2 += ","; l_pSignalArray2 += l_pSelectedSignal5; /// for read from LIN g_Status = CreateSession(l_pSelectedDatabase, l_pSelectedCluster, l_pSignalArray, l_pSelectedInterface, 0, out g_SessionRef); // for writing to LIN g_Status = CreateSession(l_pSelectedDatabase, l_pSelectedCluster, l_pSignalArray2, l_pSelectedInterface, 3, out g_SessionRef2); // ValueBuffer[0] = 0x01; ValueBuffer[1] = 0x00; // write g_Status = WriteSignalSinglePoint(g_SessionRef2, ValueBuffer, 16); ///////////////////// read g_Status = ReadSignalSinglePoint(g_SessionRef, out ReadValueBuffer, 24, out TimestampBuffer, 24); return; } } }
03-07-2016 07:04 AM
I don't know .NET, but looking at your code, you are marking "ReadValueBuffer" as an 'IntPtr'. This is actually a double-precision floating point value.
I don't know if this helps.
09-15-2016 01:55 PM
hummm,, its 2016 and no support for .NET framework? I wonder if NI is pushing customers to competitors for in-vehicle CAN (ValueCAN, Vector CANTech, etc) for not being able to interface to new development environment. Afterall, Measurment Sudio uses WPF. If I have the hardware; why do I need to shling another $1k for development environement that I can get for free from Microsoft. Its not rocket science; only CAN messages.
06-21-2017 03:59 PM
Any luck? I am also looking for C# code for LIN2.0.
