08-17-2015 12:53 PM
I tried it. This error came. Even when I changed the second interface to CAN 2, the same error was there.
08-17-2015 02:02 PM - edited 08-17-2015 02:05 PM
Well did you read the error? Did you read the manual? If you did you would see that the c-series devices need to have external power. I think its dumb too, but it does.
http://www.ni.com/datasheet/pdf/en/ds-97
http://digital.ni.com/public.nsf/allkb/DB8AAAB68B1D18D586256EF6004E4CBC
http://digital.ni.com/public.nsf/allkb/1FC16F7B4EDF3C5B86256C1400763CD4
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
08-18-2015 08:09 AM
Hi manu9511,
Hooovahh is correct - you're probably getting that error either because you're not powering the bus at all or because it's being powered incorrectly. The 9862 Operating Instructions talks about the bus power requirements on page 5, and has a pinout on page 6. You'll need to connect positive voltage to pin 9 (Vsup), and the ground to pin 3 (COM).
Kind Regards,
