Automotive and Embedded Networks
NI-DNET - Wierd Behavior with Simple WHO
I have 1 devicenet device (an Allen Bradley 842D Absolute Encoder) attached to the network and am trying to "simple WHO" the device from NI MAX.  The wierd behavior is this:
I set the MAC ID to 40 (or any other number) and Rate to 500kbps.  Using the simple WHO function,  I can "see" this device on the network when using any MAC ID OTHER THAN 40 (or whatever number I set it to).  If I select the correct MAC ID,  i get this error message:
NI-CAN (Hex 0xBFF6200F)  The devicenet duplicate MAC ID check failed for the I
Select a different Interface MAC ID in Setup Online Info.
When I select to view a MAC ID other than the actual MAC ID,  I can then select the instrument and view the properties associated.  I'll be using the device with an OPC server so I don't have Labview installed on this computer to check and see if the I can really talk to this device.  Another note.  The device has a Status LED that "flashes" Green.  A "steady" Green light is what i'm looking for.  Flashing green means the device is "Active  but not allocated to Master"
From the Knowledge base article: "3A2E8THR",  error 0xBFF6200F translates to a BAD MAC ID.   I'm not how to correct this situation.  Any suggestions?
Regis
Regis
(3,455 Views)
Hi Regis,
When you set the ‘Interface MAC ID’ in Simple Who, you set the MAC ID of your local DeviceNet interface card (the master/scanner), not the other device(s) on the bus.
-B2k
(3,451 Views)
Thanks...i just got to reading that in the Help file .....My mistake...
Regis
(3,445 Views)
