02-27-2006 12:11 PM
02-28-2006 11:00 AM
Hi Olav,
This does mean that development of new applications in LabVIEW 6.1 is not supported. With the release of LabVIEW 8.0, support for LabVIEW 6.1 was dropped. National Instruments supports two versions of LabVIEW back from the current version.
An application created in LabVIEW 6.1 with version 1.3 of the NI-DNET drivers should work fine with NI-DNET version 1.4.2 installed. It should work, but the installation of the new drives will remove the 1.3 functionality from LabVIEW and install 1.4.2 functionality. Version 1.4.2 of the drivers does not install support in LabVIEW 6.1, so the functions will be removed from, but not replaced in the LabVIEW 6.1 folder. The 1.4.2 functionality will only install into later versions of LabVIEW. Let me know if you have any other questions!
Chris R.
02-28-2006 01:43 PM
03-01-2006 02:48 PM
