12-23-2015 08:51 AM
My application was developed years ago using the NI-CAN Channel API on PCI CAN cards. I have successfully used that old application on newer XNET CAN cards by installing the NI-CAN Compatibility Library. Here's my question: Is there a way to use that old app with an NI 9866 LIN module, perhaps through the NI-CAN Compatibility Library?
12-28-2015 04:27 PM
Hi ClausB!
Unfortunately, from my current understanding, the compatibility library that you are discussing does not support LIN. More information about what is supported can be found in this document:
http://digital.ni.com/public.nsf/allkb/846160FE77DEA0DE862579C10075215E?OpenDocument
Thanks!
