04-22-2014 04:07 PM
I have a few questions:
Does the OBD-II CAN Car Monitor Demo is designed to work exclusively with the Automotive Diagnostic Command Set?.
If I haven't the ADCS I will never could try this demo?
I'm trying to run this OBD demo, but I have this error attached in the image (and also I don't have the ADCS)...where could I found the niyanci.dll?.
04-29-2014 02:06 AM
The OBD-II CAN Car Monitor Demo requires ADCS, you can't run the Demo without ADCS.
You can download an evalution version of ADCS from:
http://www.ni.com/download/automotive-diagnostic-command-set-for-ni-can-1.2/4145/en/
Best regards
04-29-2014 09:09 AM
Thanks Gucky, that was really helpful...now I can run the demo 😄
Best regards
04-29-2014 03:19 PM
Hello again,
I was looking the block diagram of the demo, and I find the "OBD Setup.vi" and "error in (no error) cluster" disconnected, see attached image "OBD2_01".
So I think that the cluster must be connected like in the second attached image "OBD2_02"...
...but what about the OBD Setup.vi ? ...also this vi it's in blank so I don't understand his function.
Thanks for help.
Best regards.
