03-20-2013 06:32 AM - edited 03-20-2013 06:33 AM
Ok now I dont have the revious problem but this one. Diagnostic command timeout. A responce from ECU was not received. Is it a problem with car can it be somehow protected from outside access? Or is it something else? Thanks for help.
03-21-2013 05:24 AM
Is this example supports SEA J1939 protocol which is designed for heavy duty vihicles ?
03-21-2013 05:40 AM
The Automotive Diagnostic Command Set doesn't support the SAE J1939 protocol.
04-10-2013 01:33 PM
Hello
Alright it's working now. I was trying to power up that module from car via ODB connector but it doesnt work. You really need that Can Breakout box and right ID's to ECU. May I have another question could you explain ODB setup block to me in detail? I know you have written something about it but could you expand on it? Could not find any help to it. Thank you very much.
04-11-2013 03:42 AM
the OBD setup sets two "Automotive Diagnostic Command Set" properties.
1. "Wait Time CF (STmin) = 0
2. "Time between Waits (T_W) = 1
If you need information about these properites take a look at the "Automotive Diagnostic Command Set" manual on page 6-25.
04-16-2013 02:11 PM
Will the NI 9862 be compatible with CAN BUS SAE J1939, or do I need to use a different setup?
04-17-2013 12:35 AM
I assume your request is not refering to OBD which we already discussed here.
Are you asking if NI 9862 supports J1939 in general?
J1939 is a high level protocol based on CAN, so yes of course the NI 9862 is able to do J1939 based communication.
So far NI-XNET has no build in support for J1939, but there is some reference implementation posted:
04-17-2013 07:53 AM
Yes, THANKS. I'm just beginning at this with a new project. Your like is exactly what I needed.
08-16-2013 03:22 AM
Hello everyone,
I have purchased a NI 9862 module and I was wondering if I will be able to use it in order to communicate with a CANopen device.
By reading the forum I get that the NI-XNET does not support CANopen but isn't there a way to communicate with CANopen devices with this particular module?
08-24-2013 02:01 AM
Hello LazyYogi,
Welcome to the NI Forums!
Please, if you have a question, open a new topic for that specific question in the future, since it can get lost in already closed, or old topics!
To answer your question, the NI 9862 is not supported with the CANopen LV Library. Instead there is a 9881 CANopen Module that is supported by the CANopen driver which is very similar to the Library.
The 9862 is an XNET Module, and there is a chance that some CANopen functions may work, it is not supported!
Peter
