07-22-2016 06:51 AM
I'm currently working on a NI9144 chassis with a CAN 9862 module.
I wondered if it's really necessary to use an additional power supply for the 9862 module (as indicate in the datasheet) considering i'm using it with the 9144 chassis ? Is it possible to use the module juste with the chassis ?
Thank you !
Solved! Go to Solution.
07-22-2016 07:39 AM
The 9862 requires bus power to provide power to the transceiver. There is no way for it to get it directly from the backplane.
07-22-2016 07:59 AM
Ok, thank you 🙂
