Automotive and Embedded Networks
Multiplexe​d CAN signals Conversion with XNET
Hello all,
I’m using NI XNET Conversion to convert CAN Frames to Signal Data.
As per my attachment this is working fine but, when I’m giving Multiplexed Signals then its giving Error.
Error Code:   “ 1074384751”
                                NI-XNET: (Hex 0xBFF63091) For Signal Output sessions, the multiplexer Signals used in the session must be specified explicitly in the Signal list.
Please help me how can convert CAN Raw Frames to Signal values for these kind of Signals.
Thanks & Regards
Munna
Munna
(7,245 Views)
Hello all,
Please let me know if anyone have idea about this issue.
Best Regards,
Munna
Munna
(7,225 Views)
Hello all,
Please respond to this.
Best Regards,
Guru
Munna
(7,184 Views)
I have had luck adding the command byte channel to my signal list. The command byte data will then be in you data. I just ignore it.  I add this channel above the signal it corresponds with.
(7,166 Views)
Accepted by topic author Munna232
Hello all,
Thank you so much for support as always.
Yesterday I solved this issue..  Its explained in XNET User Manual..
Sorry for late reply.
Munna
(7,154 Views)
Hello Munna,
Can you please tell me where in the Manual did you find it? I have exactly the same problem and I just can't find any solution for it... thank you.
(4,763 Views)
i am facing same issue. Any solution for it?
(2,507 Views)
