05-12-2006 03:34 AM
05-12-2006 08:34 AM
Hi developer,
Third post today? here is an example of how to read 4 consecuitive frames after a write.
You should change your program to have the initialize and open only once before you enter the while loop. The Interface handle is the only value you have to provide to your write and read functions. And when you stop the program the close will clear the handle, thus the close should also be outside your main loop once.
DirkW
