I'm using an Allen-Bradley 1784-PCDIS PCI scanner card, and it does not show up in MAX. I've un-installed the card, un-installed NI-DNET 1.41, then re-installed NI-DNET, installed the scanner card, and it still doesn't show up. The card does communicate if I use A-B's RSNetworx or IOLinx, but if I try any LabView VI's, I have no luck. Any ideas or suggestions?
I'm running Windows XP Professional with LabView 6.1.
Additional note - the same PC has a NetMos dual RS-232 card installed, which also doesn't show up in MAX, but it works perfectly with any VI that I test it with.
