01-20-2014 06:11 PM - edited 01-20-2014 06:40 PM
I have two CANs CAN1 and CAN0 hooked to a breakout box 1 ea, CAN Breakout Box - 14-Port Breakout Box With Power and Termination 2 ea, NI USB-8473 - 1-Port, High-Speed CAN, USB Interface I have LavView 2013 Ver. 13.0f2 (32-bit) I am using "c" libraries: C:\Program Files (x86)\National Instruments\NI-CAN\MS Visual C\nicanmsc.lib which has a "Date created" 3/13/2012 3:35 PM I think the version number is 2.7.4 but I don't know where to find this number. I have Windows 7 I would like to send J1939 Messages on CAN1 using LabView (Which I have working.) I would like to receive j1939 Messages on CAN0 using MS .c program (Which I have working for BAM messages, but not for RTS/CTS messages to a DA (Destination Address, Messages with PF < 240 0xF0)) I can't seem to get the RTS CTS non-BAM messages to work. I get the RTS, but I don't know how to configure a CAN to be associated with "BB" DA (Destination Address). I also am sending the CTS with ncWrite but I still get a "Connection Abort Messgage" I think I need to configure the two CANs with an Address. I would like CAN1 the Sending CAN to be "AA" (This one would also receive the CTS message) and CAN0 the Receiving CAN to be "BB" (This one would also send the CTS message) Below is what I am trying: I am trying to send on CAN1 a J1939 RTS message: 1CC2BBAA where 1C - 0001 1100 PPSP PPED aaOr rrDP ddFi iiP 7 - Low priority . - SOF will be set to 1 in the LabView program by ORing 0x20000000 ..C2 - 194 - PF Parameter Group Label: Monitor Performance Ratio PGN Desc.: Legislated On-Board Diagnostics requirements specify that manufacturers must monitor all emission and OBD system related components throughout the expected life of the vehicle. ....BB - 187 - PS/DA A destination Address "BB" that I made up. I would like CAN0 to be configured with this Address but I don't know how I need to do this? ......AA - 170 - SA A source Address "AA" that I made up. I would like CAN1 to be configured with this Address but I don't know how I need to do this? I have set up some test data |LS MS|LS MS|LSD MSD|LS MS|LS MS| |F4 01|0A 00|8D 02 F8|14 00|0A 00| which is for ----------- ------- ---------------------------------------------- SPN Position in PGN SPN SPN Description ----------- ------- ---------------------------------------------- 01-02 3048 Engine Ignition Cycle Counter 03-04 3049 OBD Monitoring Conditions Encountered 05-06, 7.6 3066 SPN of Applicable System Monitor 08-09 3067 Applicable System Monitor Numerator 10-11 3068 Applicable System Monitor Denominator ----------- ------- ---------------------------------------------- If you flip the LSD and MSD around you get this: (I just made up these numbers for testing.) |MS LS|MS LS|MSD LSD|MS LS|MS LS| |01 F4|00 0A|F8 02 8D|00 14|00 0A| 01 F4 => 500 Engine Ignition Cycle Counter 00 0A => 10 OBD Monitoring Conditions Encountered F8 02 8D 1111 1000 0000 0010 1000 1101 .... .000 0000 0010 1000 1101 "." - Unused bits set to 1 0 0 0 2 8 D 00028D => 653 SPN of Applicable System Monitor Engine Injector Cylinder #03 00 14 => 20 Applicable System Monitor Numerator 00 0A => 10 Applicable System Monitor Denominator I used the following LabView .vi example to send the message: http://www.ni.com/example/31215/en/ Then click the link on the right "J1939 Transport Protocol" Which will get you this zip file: "transport_protocol_8.6_2v.zip" Inside this zip file ".....\transport_protocol_8.6_v1.1\transport_protocol_8.6\J1939 Multi Packet Frame\Examples\NI CAN Frame Example\J1939 NI CAN Frame Example.vi" Load this into LabView I used the following "C" example to read the message: C:\Users\Public\Documents\National Instruments\NI-CAN\Examples\MS Visual C\Frame API examples\CAN Receive\CAN Receive.c I wrote some "c" code to test for the RTS message and then do a ncWrite to send a CTS. It isn't working and I keep getting "Connection Abort Message" I don't know what I am doing wrong. Below is the debug output with my comments (CMT:) ------------------------------------------------------------------- CMT: EC message with 0x02000000 SOF ORed in by LabView CMT: and priority changed form 7 to 6 (110) CMT: making 38 CMT: 0011 1000 CMT: PPSP PPED CMT: aaOr rrDP CMT: ddFi iiP CMT: 1 10 - 6 Priority CMT: EC - Transport Protocol - Connection Mgmt CMT: BB - DA (Destination Address) CMT: AA - SA (Source Address) CMT: 10 - 16, RTS Message CMT: 0B 00 - 11 Mes Size CMT: 02 NumPackets CMT: - 255 MaxNumPackets FF CMT: - 00C2BB PGN BB C2 00 CMT: CMT: CMT: c 10:32:51.548 38ECBBAA CAN Data Frame 8: 10 0B 00 02 FF BB C2 00 iMessageDataSize = :0: RTS Start :10: (10 - RTS) RTS Mes Size :000B: (11) RTS Num Pack :02: (2) RTS Max Num Pack :FF: (255) RTS PGN :00C2BB: CMT: Below is the CTS send data I created to send with ncWrite CMT: 11 - Fixed 17, for EC message PGN 60416 CMT: 02 - Max number of packets that can be sent CMT: 01 - Next sequence number to use CMT: FF FF - Reserved. Filled with FFs CMT: BB C2 00 - 00C2BB PGN ....In SendCTS.... iBAMRTSCAMPgn = :00C2BB: CTS ucData[0] = :11: CTS ucData[1] = :02: CTS ucData[2] = :01: CTS ucData[3] = :FF: CTS ucData[4] = :FF: CTS ucData[5] = :BB: CTS ucData[6] = :C2: CTS ucData[7] = :00: ActualDataSize = :1: CMT: I expeced a Data Transfer message "EB00" or "38EBBBAA" but I CMT: get "38ECBBAA" with "FF" in the 1st data byte which means CMT: "Connection Abort Message" iPri = :6: iEdpDp = :0: iPf = :EC: iPs = :BB: iGe = :00: iPgn = :EC00: iSa = :AA: c 10:32:52.799 38ECBBAA CAN Data Frame 8: FF FF FF FF FF BB C2 00 iMessageDataSize = :0:
01-20-2014 06:13 PM - edited 01-20-2014 06:42 PM
------------------------------------------------------------------- Below is the "c" code to test for the RTS and then send the "CTS" ------------------------------------------------------------------- #define CAN_BUF_SIZE 150 ... NCTYPE_UINT32 Baudrate = NC_BAUD_125K; ... // Call ni-can function // Configure the CAN Network Interface Object // See "C:\Program Files (x86)\National Instruments\NI-CAN\MS Visual C\Nican.h" for definisions of NC_ (NI CAN) defines. AttrIdList[iNumAttr] = NC_ATTR_BAUD_RATE; AttrValueList[iNumAttr] = Baudrate; ++iNumAttr; AttrIdList[iNumAttr] = NC_ATTR_START_ON_OPEN; AttrValueList[iNumAttr] = NC_TRUE; ++iNumAttr; AttrIdList[iNumAttr] = NC_ATTR_READ_Q_LEN; AttrValueList[iNumAttr] = CAN_BUF_SIZE; ++iNumAttr; //CMT: I changed the write buffer from 0 to 150 becaue I though when I did a CTS I would //CMT: need some buffer size to be able to write. It didn't help. AttrIdList[iNumAttr] = NC_ATTR_WRITE_Q_LEN; AttrValueList[iNumAttr] = CAN_BUF_SIZE;//0; ++iNumAttr; AttrIdList[iNumAttr] = NC_ATTR_CAN_COMP_STD; AttrValueList[iNumAttr] = 0; ++iNumAttr; AttrIdList[iNumAttr] = NC_ATTR_CAN_MASK_STD; AttrValueList[iNumAttr] = NC_CAN_MASK_STD_DONTCARE; ++iNumAttr; AttrIdList[iNumAttr] = NC_ATTR_CAN_COMP_XTD; AttrValueList[iNumAttr] = 0; ++iNumAttr; AttrIdList[iNumAttr] = NC_ATTR_CAN_MASK_XTD; AttrValueList[iNumAttr] = NC_CAN_MASK_XTD_DONTCARE; ++iNumAttr; // Configure CAN0 so this "C" program can read from it. // We will be hooking LabView to write to the Can on CAN1 // See pg. 11.9 in // "C:\Program Files (x86)\National Instruments\NI-CAN\Documentation\NI-CAN Hardware and Software Manual.pdf" Status = ncConfig( Interface, // Object Name: CAN0 iNumAttr, // Number of Attributes 8, 0-7 AttrIdList, // List of Attribute IDs AttrValueList // List of Attribute Values ); if (Status < 0) { PrintStat(Status, "ncConfig"); } // open the CAN Network Interface Object Status = ncOpenObject(Interface, &gNetIntfObjhRx); if (Status < 0) { PrintStat(Status, "ncOpenObject"); } ... // Check for RTS Message if (0x10 == iBAMRTSCAMStart2010FF) { // Print the RTS printf("RTS Start :%02.2X: (10 - RTS)\n", iBAMRTSCAMStart2010FF); printf("RTS Mes Size :%04.4X: (%d)\n", iBAMRTSMesSize, iBAMRTSMesSize); printf("RTS Num Pack :%02.2X: (%d)\n", iBAMRTSNumPack, iBAMRTSNumPack); printf("RTS Max Num Pack :%02.2X: (%d)\n", iBAMRTSMaxNumPack, iBAMRTSMaxNumPack); printf("RTS PGN :%06.6X:\n", iBAMRTSCAMPgn); // You have upto 200ms to send thi CTS message SendCTS(iBAMRTSNumPack, 1, iBAMRTSCAMPgn); } ... /***********************************************************\ |* SendCTS |* -- SendCTS after getting RTS so Data Transfer can be done \***********************************************************/ int SendCTS( int iBAMRTSNumPack, // // I : Number of Packets requested, Put into the data of CTS message Data[1] Zero Based int iStartSeqNum, // // I : Start sequence number (1), Put into the data of CTS message Data[2] Zero Based int iBAMRTSCAMPgn // // I : PGN 00C2BB, put into the data of CTS message Data[5-7] Zero Based ) { /**********************************************************\ |* Variables \**********************************************************/ NCTYPE_STATUS Status = 0; NCTYPE_CAN_FRAME oCFSend; // // CAN Frame to write unsigned char ucData[8]; //CMT: I don't know why id is 5 here? //CMT: I kept it because all the examples that use ncWrite have id=5 //CMT: xx int id = 5; // // See J1939-xx pg. xx 0-4 Not int iNdx = 0; // // Loop counter int iPriority = 7; int iEdpDp = 0; /**********************************************************\ |* Code \**********************************************************/ // Set up the PGN etc... // 0001 1100 1110 1100 0000 0000 0000 0000 // PPSP PPED Pf....... Ps/DA.... SA....... //id = 0x1CEC0000; // Configure the RTS message ucData[0] = 0x11; // // CTS Message Fixed at 17 ucData[1] = iBAMRTSNumPack; // // Max number of Packets that can be sent at once. (Not larger than byte 5 of RTS) ucData[2] = iStartSeqNum; // // Next sequence number to start with ucData[3] = (char)0xFF; // // Filled with 0xFF ucData[4] = (char)0xFF; // // Filled with 0xFF printf("\n....In SendCTS....\n"); printf("iBAMRTSCAMPgn = :%06.6X:\n", iBAMRTSCAMPgn); ucData[5] = (iBAMRTSCAMPgn & 0xFF); ucData[6] = (iBAMRTSCAMPgn & 0xFF00) >> 8; ucData[7] = (iBAMRTSCAMPgn & 0xFF0000) >> 16; // Print the CTS messages printf("\n"); for(iNdx=0; iNdx<8; ++iNdx) { printf("CTS ucData[%d] = :%02.2X:\n", iNdx, ucData[iNdx]); } printf("\n"); // Store data into CAN Frame obj oCFSend.DataLength = 8; memcpy (oCFSend.Data, ucData, oCFSend.DataLength); oCFSend.IsRemote = 0; // // I don't know what this does. oCFSend.ArbitrationId = id | NC_FL_CAN_ARBID_XTD; // 0x20000000; // // I think this is the SOF bit Status = ncWrite( gNetIntfObjhRx, oCFSend.DataLength, (void *)&oCFSend ); return 0; } // end SendCTS() -------------------------------------------------------------------
01-20-2014 06:14 PM - edited 01-20-2014 06:39 PM
01-20-2014 06:14 PM - edited 01-20-2014 06:37 PM
01-21-2014 07:59 AM
Hello jh99
What debugging have you followed?
Have you identified if the code that is failing is the "C example"? I understand you modified the CAN Receive.c to read the message.
Did you test the code that is sending the message? Is it working?
What function is giving you the error?
Frank R.
01-21-2014 10:21 AM - edited 01-21-2014 10:35 AM
I put printf statements in the "c" code
and printed the messages and data as they come in.
I think the code is working. I think I need to send a CTS when receiving a RTS but I don't know how to do this.
I also think I need to set up SA (Source Addresses) for the two CAN's I am using but don't know how to do this or
if the Addresses are in the CAN0 and CAN1 already and I just have to query them some how and use those numbers instead of AA for CAN1 and BB for CAN0.
I started reading J1939-81 and it has a bunch of stuff on Source Address and Names.
The code I use to send the message is the LabView .vi file.
It sends the message and my "c" code reads the message.
The BAM (Broadcast Announce Message) work and I get Data Transfer PGN messages with the data.
(Pf >= 0xF0 (240))
I think this works because It is a broadcast message and doesn't require a CTS.
When I send a message with Pf < 0xF0 (240) then it is a message to a DA (Destination Address).
I then get RTS message and I have to reply with a CTS within 200ms or I get a Connection Abort Message.
I don't know how to configure the two CANs I have to have Addresses or Names or if they already have
Addresses and Names and I just need to query them and use those numbers instead of the numbers I made up.
(AA BB).
The error "Connection Abort Message" isn't really and error but a message indicating that I didn't
send the CTS message quick enough.
The problem I am having is how to create the CTS message and send it with ncWrite.
Also, how to get/set the Addresses so the RTS/CTS can use those values for the SA and DA.
John
01-22-2014 11:23 AM
Hello jh99
I researched for available examples in the community, the manuals, the shipping examples and I did not find references to NI-CAN RTS/CTS messages. I am just sying that I could find an example already built, I am not saying you cannot do it. You should test it and analyze it deeply in order to advance on that. You could also evaluate other examples rather than CAN Receive.c maybe..
I found a second API that you could evaluate as well (as an additional reference, however we should research to check if it includes examples using the RTS/CTS for J1939 ).
Automotive Diagnostic Command Set User Manual
NI Automotive Diagnostic Command Set
Frank R.
01-24-2014 10:01 AM - edited 01-24-2014 10:03 AM
I fixed the program.
it was the following statement:
was this:
Status =
ncWrite(
gNetIntfObjhRx,
oCFSend.DataLength,
(void *)&oCFSend
should be this:
Status =
ncWrite(
gNetIntfObjhRx,
sizeof(oCFSend),
(void *)&oCFSend
01-24-2014 10:21 AM
I evaluated the example:
"C:\Users\Public\Documents\National Instruments\NI-CAN\Examples\MS Visual C\Frame API examples\Transmit Receive same Port\Transmit Receive same Port.c"
and it had the ncWrite command that
led me to the fix.
