06-27-2005 11:22 PM
06-28-2005 01:42 PM - last edited on 01-29-2024 09:35 AM by migration-bot
So are you looking for a card that can function in both high speed and single wire at the same time? Your best option is the XS, 2 port cards.
NI PCI-CAN/XS2
NI PXI-8464/2
Logan S.
06-28-2005 01:50 PM - last edited on 01-29-2024 09:36 AM by migration-bot
If you need to use the PCMCIA form factor, you can use a 'PCMCIA-CAN Transceiver Dongles' that has a single wire port. Check out the PCMCIA-CAN Transceiver Dongles site.
The 'Cable Assembly, PCMCIA-CAN Series 2, SW' (part number 191012-01) features one single-wire port.
The 'Cable Assembly, PCMCIA-CAN Series 2, HS/SW' (part number 191009-01) features one high-speed and one single-wire port (only useful in combination with a 2-port PCMCIA-CAN card)
Please note that you need to have a Series 2 PCMCIA-CAN card in order to use the single-wire transceiver dongles.
-B2k
07-02-2005 11:21 PM
I assume the High Speed 83.33k your refer to is the high-speed mode of the Single-Wire transceiver, not the High-Speed transceiver.
Yes. The Single-Wire dongle for the PCMCIA-CAN card will function just fine with your GMLAN application.
Within your application, you can set the Transceiver Mode property to switch between Normal Single-Wire communication (33.33k) and high-speed Single-Wire communication (83.33k).
