Automotive and Embedded Networks
How to read ASCII ID from A2L file using MC XCP Get ID vi
I am using ECU M&C toolkit 15 with NI USB 8473s. I am trying to read ASCII ID (to read software version from A2L file)using MC XCP GET ID VI (choosing type 0). With following code I have problem as sometimes it gives correct ID string while sometimes error -1074388957.
Could you please help to solve this problem.
Thank you.
Cheers,
SD
(3,288 Views)
Accepted by topic author ImHappy@RBG2017-04
You should add the MC ECU Close.vi to the end of your program before the Error Out.  Constantly opening a file without closing it can cause odd behavior at times.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,251 Views)
Thank you it solves problem.
(3,222 Views)
