Reply
How to distinguish between frames that comes from my TX CAN Object and frames that comes from the network?
Go to Solution
Hy,
I have a Can Object that transmit data to specific id.
I expect to get frame  from the network with similar id and data.
How would I know that the data arrived from the network?
(If I listen to the data from the CAN Interface, I can't distinguish between the data that I transmit and between the data that comes from the net)
Thanks in advance,
Aviad
Message 1 of 4 (3,467 Views)
Reply
Re: How to distinguish between frames that comes from my TX CAN Object and frames that comes from the network?
Start with the simple things: Hardware, Driver, OS, Programming Environment...
Message 2 of 4 (3,464 Views)
Reply
Thankes.
I work with:
  • Hardware: PCI-CAN Series 1,
  • Driver: NI-CAN 2.7.3
  • OS: Windows xp
  • Programing environment: QT C++.
Message 3 of 4 (3,458 Views)
Reply
Highlighted
Accepted by topic author aviadCielo
‎08-27-2015 06:09 PM
Since you are using NI-CAN Series 1, which doesn't support any self-reception, I presume you are using two CAN ports... one to do your normal transmission and one to listen to the frames from the CAN bus?
If this is the case, the only option that I see for you would be to compare the received payload with the transmitted payload to detect the frames that you send. This will only work if you send and receive different payloads, but that is probably something that is generally true. If that is false, then you really don't have any good option with Series 1 (or even Series 2) and NI-CAN.
We do have a different product, NI-XNET, which provides a self-reception setting (like Series 2 NI-CAN), but when you receive the frame it contains a flag that indicates if it was received from the network or was received via self-reception. This would obviously be the simplest (and probably only guaranteed) way to achieve your goal.
Message 4 of 4 (3,453 Views)
Reply
