Hi Shawon,
I need to know the exact output of your Java, I have attached a VI and I need you to follow the instructions.
This VI should allow me to see the exact output you are getting, so I can work out what you need to do.
Once you have run the VI, can you go in to your Java code and change timeStamp = System.currentTimeMillis() inside HumiditySample.java and divide the timeStamp by 1000 as Labview timestamps deal in seconds, and the numbers after the decimal point relate to milliseconds.
After you have changed your code, plese retry with shawonclient-mod.vi
Regards
James
NI UK
