Automotive and Embedded Networks
How can i integrate canoe into labview?
I'm having trouble using canoe from labview.
I want to receive and send can-messages with a vector cancardx (pcmcia). Using the internet i found out, that this sort of thing is possible, but didn't find any tutorial or any hint on how to do this. Could someone please hint me to the right direction?
thnx in advance.
merlin
(4,703 Views)
If you look in the back of the CANcard manual, you should see some info about interfacing to the CANcard driver DLL. You can then interface Labview to the DLL for the CANcard. I Don't know anything about interfacing to the CANoe program, but you probably will not be able to interface Labview to the CANcard at the same time as CANoe, because the CANcard can not be shared.
(4,698 Views)
