Automotive and Embedded Networks
How can I use the ni-can using visual basic
I'm having some troubles using the channel API in visual basic. I want to getnames (using nctgetnames) but the .bas module in VB has the channelList as a byte, but in the channel API documentations says that it should be a string. So can you tell how can I get the channels names from a vector database?
(4,276 Views)
That sounds like a bug in the header file.
Normaly it should be: ByRef ChannelList As String,_
You can modify that manualy in the header file.
That should work.
(4,275 Views)
I already try your idea an it doen't work!
Any other idea?
The software crash after the nctGetnames function runs.
(4,275 Views)
Catalina,
After doing some digging it looks like this might actually be a small bug. There appears to be a problem with the wrapper code. In the coming days either myself or another will try and post a workaround solution.
Craig H.
NI Applications Engineering
(4,275 Views)
It is not a bug in the function definition, but there is a wrapper function missing. Use the following code to read the names from NI-CAN instead.
Function nct_GetNames(ByVal FilePath As String, ByVal Mode As Long, ByVal MessageName As String, ByVal BufferSize As Long, ByRef List As String)
' This function wraps nctGetNames function and makes the names from NI-CAN available for the
' user in string format
Dim str() As Byte
Dim i As Integer
Dim Status As Long
ReDim str(BufferSize + 1)
i = 1
nct_GetNames = nctGetNames(FilePath, Mode, MessageName, BufferSize, str(0))
List = Chr(str(0))
While ((i < BufferSize) And (Chr(str(i)) <> "\0"))
List = List + Chr(str(i))
i = i + 1
Wend
End Function
Call this function instead of nctGetNames directly.
(4,277 Views)
Ni has fixed the .bas file to use the nctgetnames function with VB
replace the .bas file with this one you can find attached.
(4,260 Views)
