NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Ultan
Help with J1939 Transport Protocol Reference Example
Anyone can help me out of the problem for no reply from ECM using J1939 Transport Protocal Reference Example?
http://zone.ni.com/devzone/cda/epd/p/id/6215
I am currently using MEFI4B ECM, cRIO9023, X.Net 1.4.0, NI9862 and Labview 2011.
The ECM is powered up by DC 12 Volt power supply and only connect with NI 9862 through CAN H and CAN L. Since I want to collect the history information from ECM, I have not connected the ECM with an engine. All the other PINs except CAN H, CAN L and power are empty.
The problems I am now encoutering:
   After I run the example, I can receive the broadcast from ECM (they are current engine status such as):
    0xCF00400
    0xFFCA00
    0x18FEEE00 etc.,
    However, when I request ECM to send the specific information to NI 9862, nothing can I receive:
     For example, I send
     Request (NI 9862 Source Address 03)
       ID:               0x18EAFF03  (Request Message)
       Data Field: 177 254 0 255 255 255 255 255 (First 3 byte, ECM historical information PGN)
     I expect to receive the incoming message ID: 0x1CEEB100 and the relevant data field. However, I cannot receive this ID.
1. For my understanding, I send the request message to ECM, the ECM should broadcast its information on the CANBus. Why can't I receive this broadcast message? I try other type messages, also no expected reply received by NI 9862
2.  I set the device source address as 3 by keying in the value on the setup. After I run the program, will the address (03) be claimed by NI 9862?
Thanks for your concerned!
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
