08-29-2011 04:22 PM
I'm trying to get the product number and name of the National Instruments card installed on my computer. According to the manual when I get the property for nxPropDev_Name I should get NI PCI-8512 (2 ports) for an NI PCI-8512 device. Instead I get an empty Cstring. For nxPropDev_ProductNum I should get 8512 for an NI PCI-8512 device, but instead I get this number: 3435973836. Below is a snippet of the code I'm using. Is there something I am doing incorrectly? Thanks int propSize; int cpropSize; u32 propName; CString cpropName; char *l_pSelectedInterface = "CAN2"; char *l_pFrameArray = NULL; char *l_pSelectedDatabase = ":memory:"; char *l_pSelectedCluster = ""; g_nxStatus = (*m_pNxCreateSession)(l_pSelectedDatabase, l_pSelectedCluster, l_pFrameArray,l_pSelectedInterface, nxMode_FrameInStream, &SessionRef); g_nxStatus = (*m_pNxGetPropertySize)(SessionRef, nxPropDev_ProductNum, (u32)(&propSize)); g_nxStatus = (*m_pNxGetProperty)(SessionRef, nxPropDev_ProductNum, (u32)(propSize), &propName); g_nxStatus = (*m_pNxGetPropertySize)(SessionRef, nxPropDev_Name, (u32)(&cpropSize)); g_nxStatus = (*m_pNxGetProperty)(SessionRef, nxPropDev_Name, (u32)(&cpropSize));
09-06-2011 11:14 AM
Hello Carbert,
Everything in your code looks fine to me. What version of the X-NET driver do you have installed? Also, what is the Part Number of your card, so that we can try test the behavior here on our end. I see that you have a Service Request open with us here. Once this issue is resolved, will you post back here with the results for future people that may run into similar issues?
09-06-2011 02:04 PM
I'm using NI-XNET 1.3 and the part number NI PCI-8512 - 780683-01
09-07-2011 09:44 AM
Hello Carbert,
One more thing, are you using LabWindows/CVI, or just the standard C API with another compiler (gcc maybe) ? Are you working from a specific example that you would like us to start from as well?
09-07-2011 10:57 AM
Hi TJ,
I'm using the standard C API on Visual Studio 2010. I'm not working off any specific example.
09-08-2011 08:03 AM
Hi Carbert,
The applications engineer assigned to your service request and I will see if we can reproduce the behavior that you're seeing as soon as possible. Thanks for all the information.
10-12-2011 02:21 AM
3435973836 -> 0xCCCC CCCC
This is common value for uninitialized variable in Visual C++.
So in this case function pNxGetProperty fails and since propName is a pointer, it's value stays as it was before function call. So if you initialize propName = 0, it stays 0 becouse of function failure.
Calling nxGetProperty gives error.
NI-XNET: (Hex 0xBFF6308D) The property ID you specified is not valid (or not valid for the current session mode or form factor).
And I have tested with property nxPropSession_IntfBaudRate and it works well, so environment should ok.
I'm strugling with this same problem. Several other properties are failing too, so are those unimplemented or is there some other reason for this?
10-12-2011 08:16 AM
This is probably making the impossible difficult, but you cannot get from the session back to the device directly. It is actually a separate API (right now - ideally we can improve this to make it easier in the future) called the system API to get system->device->interface type of properties.Using the system API, I am doing the following:
1) Open System
2) Get all interfaces in the system
3) Loop on the interfaces until I find one that has a name that matches the desired one
4) Once I get the interface, I can get the device that the interface is a part of
5) Once I get the device, I can then query the device for the required information (Name, Number)
6) Close System
Note: This doesn't do any error checking for simplicity, but it does get the status so you could easily apply error checking to prevent any type of ugly unexpected failures.
int l_NumInterfaces;
int l_PropSize;
u32 l_PropProductNum;
char l_PropProductName[1024];
char l_PropInterfaceName[1024];
nxSessionRef_t l_PropInterfaceRefs[32];
nxSessionRef_t l_SystemRef;
nxSessionRef_t l_SelectedDeviceRef;
int i;
g_Status = nxSystemOpen(&l_SystemRef);
g_Status = nxGetPropertySize(
l_SystemRef,
nxPropSys_IntfRefs,
&l_PropSize
g_Status = nxGetProperty(
l_SystemRef,
nxPropSys_IntfRefs,
l_PropSize,
l_PropInterfaceRefs
l_NumInterfaces = l_PropSize/sizeof(nxSessionRef_t);
for (i = 0; i < l_NumInterfaces; i++)
l_PropInterfaceRefs[i],
nxPropIntf_Name,
&l_PropSize
nxPropIntf_Name,
l_PropSize,
l_PropInterfaceName
if (!strcmp(l_PropInterfaceName, l_pSelectedInterface))
nxPropIntf_DevRef,
sizeof(nxSessionRef_t),
&l_SelectedDeviceRef
l_SelectedDeviceRef,
sizeof(u32),
&l_PropProductNum
nxPropDev_Name,
&l_PropSize
nxPropDev_Name,
l_PropSize,
l_PropProductName
break;
g_Status = nxSystemClose (l_SystemRef);
10-13-2011 12:40 AM
These changes worked well, so from my part this case is solved. Thanks alot.
10-13-2011 06:37 AM
Thanks for the update. I am glad that you were able to be successful.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
