Automotive and Embedded Networks
Error using NI9268
I'm trying to use the NI9268 CAN module for the first time (with a CRIO 9081). When i connect it i can se it in MAX but i have the following error after the auto-test : 0xBFF63001 (screenshot 1).
Then when i want to start the bus interface, i have the error 10744384758 (screenshot 2)
Do you know how to fix it ?
I already have installed all the correct drivers with the CRIO...
(3,630 Views)
The module is a CAN NI9862, sorry for the error...
(3,617 Views)
Accepted by topic author vincentlg
http://digital.ni.com/public.nsf/allkb/25002AA2FC23EFA686257E3500520E83
It is the solution if someone have the same error...
(3,605 Views)
