12-17-2009 04:14 PM
I built an executable and installer using the LV application builder. On a couple of computers when the installer is run, the error in the attached jpeg is returned.
Russell
Solved! Go to Solution.
12-18-2009 04:44 PM
Hi Russell,
Which version of LabVIEW was this built with and what versions are the Run Time Engines on the deployment machines?
As well, what are the differences between the machines that run the installer without any errors and the machines that do throw this error?
12-19-2009 06:35 AM
Everything is in version LV 8.6
12-21-2009 04:35 PM
Do all the deployment machines have the LabVIEW Run Time Engine 8.6 or 8.6.1?
Did you copy everything in the bin, license and supportfiles folders to the other machines before running the installer? Specifically, is the file NI Released License Agreement - Simplified Chinese.rtf in the license folder?
12-22-2009 11:12 AM
Thank you for your help it lead me to the source of the problem. The NI Released License Agreement - Simplified Chinese.rtf file was present but the extension was cut off because when the file was unzipped the file path was longer than Windows file path limit. So I just made the file path shorter and fixed the extension and it worked.
Russell
06-20-2012 11:53 AM
Is there any way to exclude certain languages from the installer?
In the Application Builder Build Specifications properties for an executable (.exe) there is "Run-Time Languages",
but in the Installer Properties there is no section for languages.
Brian Smith
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
