Automotive and Embedded Networks
Error 1074388697
error 1074388697 occured at CAN Start.vi
(3,761 Views)
it's probably -1074388697. The description of that error is:
"NI-CAN:  (Hex 0xBFF62127) You connected an external timebase to the CAN card using ConnectTerminals, and the timebase disappeared (disconnected) during CAN communication (objects still open). Solution: Close/Clear NI-CAN objects before stopping the hardware that provided the timebase (such as a DAQ card)." (see KnowledgeBase article # 30RFM8HR).
If the error description doesn't help, could describe your setup?
-B2k
(3,751 Views)
Thank you for responding.  I should have been more specific, how do I get rid of this error?
(3,747 Views)
My set up is CAN Demo Box and CAN Series2 card.
(3,726 Views)
Hi Kokitche,
Did you use any kind of Synchronization example, which uses typically timebase and trigger from a DAQ board?
If yes, in case of stopping this example, the timebase becomes disconnected and this means there is no timebase for the whole device (both ports on a 2 Port device).
If you run a second application at the same time on the second port, this error ocurs here.
DirkW
(3,712 Views)
