01-30-2012 10:17 AM
My C app was written with the NI-CAN Channel API and works fine on the older PCI-CAN cards. Now it's running on a PCI-8512 with NI-XNET 1.3.0 and NI-CAN 2.7.2 Compatibility Library, and it gives this error spuriously: "NI-CAN: (Hex 0xBFF62133) You set an attribute that is not supported when Virtual Bus Timing is disabled. Refer to the Frame To Channel Conversion section of the NI-CAN manual for a listing of attributes that return an error when Virtual Bus Timing is false. Solutions: 1) Set Virtual Bus Timing true (or leave as default). 2) Do not set the unsupported attribute."
My app does not use Frame To Channel Conversion nor the Virtual Bus directly, it is set to talk directly over the CAN0 hardware bus via the Channel API. Does the Compatibility Library use the Virtual Bus?
How can I avoid this error?
Thanks.
Solved! Go to Solution.
01-30-2012 11:08 AM
01-30-2012 01:44 PM
Thanks for the reply. Below is the Spy capture. Ignore the read warnings - there was no transmitter on the CAN bus. Notice that two of the three InitStart calls happen at the same time. My app is multi-threaded and each CAN task is handled by its own thread. All three threads try to init at the same time but one fails with that (bogus?) error. This was running on a quad-core CPU. I repeated the test after forcing the app to run on a single core and the error did not appear.
Is NI-CAN not thread-safe?
11740. nctInitStart ("T1,T2,T3,T4", 0, 1, 0, 44)
Process ID: 0x00000FA8 Thread ID: 0x00000B04
Start Time: 13:59:47.828 Call Duration 00:00:00.015
Status: 0 (VI_SUCCESS)
11741. nctRead (24, 1, NULL, NULL, {0}, 1)
Process ID: 0x00000FA8 Thread ID: 0x00000124
Status: 0x3FF62009
> 11742. nctInitStart ("V1,V2,V3,V4", 0, 1, 0, 0)
> Process ID: 0x00000FA8 Thread ID: 0x00000C70
> Status: 0xBFF63133
11743. nctInitStart ("Speed,Torque,Dy...gEcho,DynoEStop", 0, 1, 0, 45)
Process ID: 0x00000FA8 Thread ID: 0x00000AA8
Start Time: 13:59:47.843 Call Duration 00:00:00.016
11744. nctRead (24, 1, NULL, NULL, {0}, 1)
Start Time: 13:59:47.843 Call Duration 00:00:00.000
Status: 0x3FF62009
> 11745. nctClear (0)
> Status: 0xBFF621B0
11746. nctWrite (44, 1, {0})
Process ID: 0x00000FA8 Thread ID: 0x00000EE0
11747. nctRead (24, 1, NULL, NULL, {0}, 1)
Start Time: 13:59:47.859 Call Duration 00:00:00.000
Status: 0x3FF62009
11748. nctRead (24, 1, NULL, NULL, {0}, 1)
Status: 0x3FF62009
11749. nctWrite (45, 1, {0})
Process ID: 0x00000FA8 Thread ID: 0x00000ED4
01-30-2012 01:57 PM
01-30-2012 02:13 PM
Good catch! Sorry I missed the different error code and so did my old app - it only reports the low 10 bits.
I will add the mutex. I had to do exactly that to solve a similar problem with DAQmx a while ago.
Thanks for your quick replies.
01-30-2012 03:31 PM
The mutex worked. Thanks!
10-02-2012 01:02 PM
Chris Boyce wrote:
...a bug in how the database is being imported (multiple threads are all attempting to create a cluster with the same name, hence the "duplicate cluster name" error). While the bug will be fixed in the future....
Is the bug in NI-XNET or in NI-CAN?
Has it been fixed yet?
10-02-2012 01:09 PM
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
