Can you provide us with more contextual information about the error you are seeing?
- Are you running an example VI or your own code? Example A2L?
- Are you using the Demo ECU shipping example or a dedicated ECU?
- Can you reproduce the error with an example VI using your A2L?
- What hardware/software versions are you using?
- Do you have a CCP/XCP Trace log file of the communications between your code and the ECU? Or a Bus Monitor log if you are running on RT?
The more information you can provide us, the faster we will be able to provide meaningful support.
Jeff L
