01-11-2015 08:01 PM - edited 01-11-2015 08:02 PM
TroyK 已寫:
It is better that you look at the vxlapi.dll documentation and understand what is going on, but I added a CAN receive example to the community document anyway.
CAN Receive Example.vi added due to popular demand.
Hello , TroyK , I can use this vi work normally but I found some word I don't understan like.. "DLC"
01-11-2015 08:05 PM
http://en.wikipedia.org/wiki/CAN_bus
DLC = Data Length Code. Number of bytes of data (0–8 bytes)
01-12-2015 03:17 AM
TroyK 已寫:
Thank you,, Your answer is really helpful
01-14-2015 08:22 PM
TroyK 已寫:
So , I guess the relationship is like as below right?
DLC DATA
0000 0byte
0001 1byte
0010 2bytes
0011 3bytes
0100 4bytes
0101 5bytes
0110 6bytes
0111 7bytes
1000 8bytes
I have another question, Can "DLC=000" possibly?
01-14-2015 09:00 PM - edited 01-14-2015 09:18 PM
Yes, DLC is 4 bits.
Standard CAN DLC 0-8, value = number of bytes.
b0000 d0 0bytes (Yes, you can have zero bytes for wake-up for example)
b0001 d1 1byte
b0010 d2 2bytes
b0011 d3 3bytes
b0100 d4 4bytes
b0101 d5 5bytes
b0110 d6 6bytes
b0111 d7 7bytes
b1000 d8 8bytes
In CAN-FD number of bytes above 8 is encoded:
b1001 d9 12bytes
b1010 d10 16bytes
b1011 d11 20bytes
b1100 d12 24bytes
b1101 d13 32bytes
b1110 d14 48bytes
b1111 d15 64bytes
01-14-2015 09:30 PM
TroyK 已寫:
Yes, DLC is 4 bits.
b0001 d1 1byte
b0010 d2 2bytes
b0011 d3 3bytes
b0100 d4 4bytes
b0101 d5 5bytes
b0110 d6 6bytes
b0111 d7 7bytes
b1000 d8 8bytes
b1001 d9 12bytes
b1010 d10 16bytes
b1011 d11 20bytes
b1100 d12 24bytes
b1101 d13 32bytes
b1110 d14 48bytes
b1111 d15 64bytes
I have this question is from "Data field"
I can not understand why 0..64 ,, Is not 0..63(8byte)?
01-14-2015 09:42 PM - edited 01-14-2015 09:43 PM
DLC is a 4bit field used to specify how many bytes of data are contained in the CAN frame.
4 bits can have a value of 0-15.
For DLC values 0 to 8 the number of bytes is equal to the DLC value.
For DLC values 9 to 15 the number of bytes is determined by the table I listed before.
A standard CAN frame can have 0-8 bytes.
A CAN-FD frame can have 0-64 bytes. (BYTES! not BITS)
CAN-FD is new, prehaps I shouldn't have mentioned it. A network will be either CAN-FD or CAN but not both. You can't mix them on the same bus.
01-15-2015 12:41 AM
TroyK 已寫:
Thanks your explain,,,I think I just confused the index and length!
02-12-2015 04:07 PM
Update to my statement for accuracy accounting for emerging technology:
Actually you can mix CAN and CAN-FD if all the older CAN nodes are put to sleep in a partial networking scheme or the tranceivers they use are specially designed to filter out CAN-FD frames.
