01-05-2015 03:05 AM - edited 01-05-2015 03:11 AM
As this topic, I had a CANcaseXL of Vector ,But I don't know how to use vxlapi.dll to monitor CAN.
It's very hard to setting ,, Does anyone can share some experience how to RECEIVE CAN to us?
I will appreciate to you so much.
Solved! Go to Solution.
01-05-2015 03:17 AM
01-05-2015 09:03 AM
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
01-05-2015 07:12 PM
Munna232 已寫:
Check this....
Hey , Thanks Munna ,,
I had download your linking file ,, But I found this CAN sent part,, I don't know where is RECEIVE part...
Can you give me some guide?
01-05-2015 07:16 PM
Have a look at the document Hooovahh attached a link to.
It has everything you need.
01-05-2015 07:23 PM
Hooovahh 已寫:
Using these drivers I've had decent success. Vector sells a LabVIEW driver but it sucks.
https://decibel.ni.com/content/docs/DOC-30180
Hi , Hooovahh
Thanks for you shared this link , I try to research it , But I am not found where is CAN RECEIVE part.
There are just CAN transmit and LIN received part...
I try to used these driver , but still can not working..
Can you share step of function name to us?
01-05-2015 07:28 PM
01-05-2015 07:43 PM
It is better that you look at the vxlapi.dll documentation and understand what is going on, but I added a CAN receive example to the community document anyway.
CAN Receive Example.vi added due to popular demand.
01-05-2015 11:08 PM
Hey HOYO,
I think you have not seen that link completely.
I have added Receive part example with help of "TroyK".
Anyway, Troy posted updated code. Please use that.
01-08-2015 09:45 PM - edited 01-08-2015 09:46 PM
TroyK 已寫:
I have to thanks for TroyK,, My device of CAN can worked normally.
I know it's very hard to setup some funtion and parameter,,Your vi is very useful!
You are my superman
