07-04-2014 04:17 AM
I have developed LV software using NI-CAN driver software for my PCI CAN/2 series card and the software works perfectly. I would like to know that can I use the same LV program without modifying it with other NI CAN module (i.e. NI 9862) which uses NI-XNET platform ????
thanks in advance.
regards,
swap
07-04-2014 04:19 AM
yes, you can use your old code. check out this white paper which explains how to migrate to NI-XNET
07-04-2014 04:28 AM
Hi Gibson,
thanks for the reply.... the link is helpful.......
07-04-2014 05:24 AM
Hi Gibson,
i have one question. I read the document and after reading it I am bit confused. I want to know what compatibility layer actually do when I have to change my code say e.g. to configure and open the interface I have to use new NI XNET API instead of old NI CAN API's (same for reading CAN data also).
So my question is if I have to change my code according to NI XNET API what is the role of compatibilty layer?
This question might sound bit wierd but I am confused
regards,
swap
07-04-2014 06:12 AM
For existing NI-CAN applications to work, both NI-XNET and NI-CAN drivers must be installed. The NI-XNET installation package contains all of the necessary components for the compatibility library to function. The compatibility library translates / maps a NI-CAN function call into the equivalent NI-XNET call or property.
While the NI-XNET compatibility library for NI-CAN (NI-XCL) strives to ensure basic functionality, you cannot always completely map the library from NI-CAN to NI-XNET because of either hardware-specific features or core differences in the NI-XNET platform.
In general we do expect that you can run you NI-.CAN code as is on NI-XNET hardware. Just some functions may be incompatible or need workarounds. For a complete table, see the NI-CAN Hardware and Software Manual for Version 2.7 or later.
