10-09-2014 09:18 AM
I'd like to use 9826 High-speed CAN module associated to a compactRIO.
I'd like to know if this module is compatible with newly released LinuxRT based cRIO? (lets' say 9030 for example).
If not, what 4-slots chassis could be advised ?
Thanks !
10-09-2014 10:35 AM
Well on the product page the 9826 mentioned the following.
Several of those are the newer LinuxRT systems but they are the 8 slot. The newer 9030 isn't listed, but I'd hope that just means the product page hasn't been updated. Someone from NI will need to confirm this.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
10-09-2014 11:15 AM
XNET 14.1 does not currently support the 9862 module in the cRIO-903x, cDAQ 9132, or the cDAQ-9134. However, support for these chassis will be included in an upcoming release of NI-XNET.
10-09-2014 12:20 PM
Hi Hoovah and Jeff,
Thanks for teh replies. This leads to two more questions :
1. When will be released the next version of NI-XNET driver ?
2. Does this mean that there isn't 4-slots cRIO supporting 9862 module ?
Thanks !
10-09-2014 12:27 PM
1) The date of releases is not publicly available.
2) The 9862 does work in the 9113, 4-slot chassis.
