02-15-2006 04:49 PM
02-16-2006 10:41 AM
Hi Olav,
I can not reproduce your problem. Perhaps you can provide an example which shows the behavior?
I assume you are using multiple devices with mixed configuration of DNet and CAN? Do you have only Series 1 boards installed or also Series 2 boards?
Which CAN driver are you using for the Get Hardware Info VI?
DirkW
02-17-2006 01:22 PM
02-20-2006 02:17 PM
02-20-2006 04:49 PM
03-09-2006 07:25 PM
03-10-2006 11:06 AM
Hi Haugan,
This is unbelievable. Can you give me your Device Serial number, to check which version it is, so we can check the same with this revision?
03-10-2006 01:20 PM
03-13-2006 03:12 PM
Hi Olav,
I tried the same revision but still could not reproduce the problem. Try to use one of our hidden properties, to identify the transceiver ID correctly.
The property is 0x80020020 for ncget hardware info, and should give you a 1 for Series 1 High Speed.
DirkW
03-13-2006 03:38 PM
Maybe what I am doing the first time I use the card causes the card to go into a weird state resulting in a '5' returned. Attached is a trace of what I do the first time when it is working. After this the card starts reporting '5' and I have to reboot. You can see that I try to open an explicit message connection to myself (I use '0' as the MAC ID for my interface card) which of course returns with error. Maybe this is why I have problems? Could you try to see if you can reproduce this?
Olav Haugan
